  4. Push-button start help
45 Posts 9 Posters 3.8k Views
    I just called out to ford and they told me that their parts computers only go back to 97 so they cant create a key from the VIN number. So i was looking online for solutions and one hit me....PUSH BUTTON IGNITION! I was just wondering if anyone has any hints or help before I start this. I am confident I can figure it out myself, but any help would be wonderful. I think I need 2 switches if I am going to bypass the key... An accesory switch, and a push button for the starter.
    I dont have a manual so I can't fin any wiring diagrams, but I think I can figure it out.
      Have you thought of maybe calling a Locksmith? They can help create a key for you. Or else, go install a new ignition and get new keys and your problem is fixed. I'm sure your tumbler in your ignition has gone through wear as well so brand new keys may not even work... Just trying to save ya time.
        I thought about it... From what I am told it is fairly expensive. I have a LOT more time than money right now.
        I also encountered another barrier;The steering wheel lock... Does anyone know how I would proceed in disengaging it and taking it out?
          if you've noticed when you turn the ignition it just supplies power to a switch.
          Get a momentary 12v dc switch, and wire it up, ghetto like the rest of the probe 😛
            Any say on the steering wheel lock? Is It something electric or mechanical?
              idk rip it all out
              • RaiderR Offline
                RaiderR Offline
                Raider
                the steering lock is mechanical...what year car do you have...I can make a key for 96 and new Fords...If you pop the ignition out then you can unlock the steering lock..or call Curt's lock n key
                POWERD BY
                  well with what ever you do, good luck
                    for diagrams use mitchell joel you idiot
                      I want it before monday tony, YOU IDIOT. lol. I just got back from LF Ford. Had Hilgers print me one out of their book, but he gave me one for a 93 and i needed 1st gen.gahhh
                        Might just be easier to go to a junkyard and buy a new ignition cylinder that has a key already w/ it.
                        If not, it will be interesting doing the wiring. You are right, you will need a momentary pushbutton switch to attach to the starter wire(s) probably gonna be a black/yellow wire. As for the other switch you will need a toggle switch to be wired to at least 3 different relays.
                        Relay #1 will go to Ignition #1 (black/white wire) when activated
                        Relay #2 will go to Ignition #2 (black/red wire) when activated
                        Relay #3 will go to Accessory (blue wire) when activated
                        As for unlocking the steering, you might be able to just remove the stock ignition cylinder. Get a manual cuz I'm not sure how ford goes about removing them for this vehicle.
                        The downside to this is that anyone can steal your vehicle at any time if they can figure out what each switch does.
                          I realize that. This will be stored and only used at the track. I bought the car because it was cheap and I wanted to experiment on something cheap, and test myself on how much I can actually handle before taking on a more serious project. THere will be various break in the circuit for a theft deterant
                            Oh yeah, almost forgot. Trying to pull the ignition yesterday, i pulled the steering wheel, turn signal canceler ... etc. I have it all apart and access to the wires. I also have a momentary and toggle accesory switch. I am all ready, I just need the diagram and instructions on how to pull the ignition.
                              If this helps, I got my camera working, and heres a few pics of the current situation.
                              All torn apart...
                              Ignition breakdown
                              If someone wants to take a stab at naming the wires that would be awesome. CHeck, this ones all you.
                              • RaiderR Offline
                                RaiderR Offline
                                Raider
                                what year and kind of car...I will look for a manual in the shop for ya
                                POWERD BY
                                • RaiderR Offline
                                  RaiderR Offline
                                  Raider
                                  if its a 90-91 probe you have to drop the steering column down( remove 4 bolts) and there are 2 break away screws..the heads of the screws break off when u install the ignition cylinder...take a cut off wheel and cut a slot into each screw and use a screw driver to remove the screws...I will post a pic of the breakdown of the steering column
                                  POWERD BY
                                  • RaiderR Offline
                                    RaiderR Offline
                                    Raider
                                    if you need anymore help drop me a PM
                                    POWERD BY
                                      hELL yeah dude thanks a bunch!!!!!
                                      • RaiderR Offline
                                        RaiderR Offline
                                        Raider
                                        np man...I am a Parts God 😄
                                        POWERD BY
                                          ihey doo those pics help?
