  4. Car Updates / Progress
  5. s13 240sx build
s13 240sx build
26 Posts 13 Posters 10.7k Views
  • A
    A
    aliengotpsi
    Looks nice!!!
    What are your plans for this car? drag drift DD?
    Kevin Smith
    Straightlinedetailing.com
    • R
      R
      revolutionz_s13
      planning pretty much for roadrace/auto-x and just an all around fun car. I would like to take it to BIR when its done, and Im sure i'll make a few passes at sabin also...
      MisterCMK;207559 wrote:
      Of course the Astrovan won. I've seen one-legged children on tricycles beat v6 mustangs.
      • zbrownZ
        zbrownZ
        Looks like fun!
        good choice on injectors!
        i like the 044 in series with the walbro too, supposed to work great
        • King RicerK
          King RicerK
          looks fun nate!!
          Trafik Jamz;299122 wrote:
          • 99civic9
            99civic9
            99civic
            i wish i had a bunch of goodies like that laying around !!!
            2000 civic SiR - jdm sickness
            • F
              F
              ForestGreen
              Yummy!
              • R
                R
                revolutionz_s13
                Little update, did some work on the head over the weekend, took it all apart and smoothed out the intake runners and ports on the head a bit...didnt want to go too crazy since I dont have much experience, just wanted to smooth out the flashing from casting and take the roughness down a notch. Waiting on a some valve seals and it will all go back together hopefully towards the end of this week.
                Intake mani runners before:
                Intake port before:
                Exhaust port before:
                Intake mani runners after:
                Intake port after:
                exhaust port after:
                cylinder side of ports after:
                • zbrownZ
                  zbrownZ
                  looks good man!
                  • capitljC
                    capitljC
                    capitlj
                    You'd be amazed at how much a little "cleaning" in the heads can accomplish. I never had the cougar dynoed but the E7's I ported seemed to flow really well beyond the RPM range where most "stock" 302's fall flat on their face. Keep up the good work, it looks so much better with the new paint and wheels, can't say I'm a fan of the wheel color tho.
                    Mitch Hedberg wrote:
                    2004 Impala LS 3.8
                    • wesholeW
                      wesholeW
                      Very nice build indeed. Looking forward to seeing this one progress.
                      • D
                        D
                        dis_ill_usions
                        from what I have seen, I suggest staying away from Spec clutches... I had a stage 2 and all it was is just a nice disk with a stock pressure plate...
                        • R
                          R
                          revolutionz_s13
                          My buddy has a stage 3+ in his corvette, it holds pretty good....alot of the KA guys run spec and like them
                          • R
                            R
                            revolutionz_s13
                            Small bit of progress here. Got some more parts, a Skullworks oil block adapter, some AEM pencil coils, an Aeromotive A1000 FPR, and a set of Supertech cam followers (lifters). I sent the head to the machine shop for a 3angle valve job, and then proceed to assemble the head. I also put the oil block adapter on and installed the Xcessive windage tray/crank scraper, and had to do only a slight amount of clearancing for the crankshaft. Im waiting for a couple more things, hopefully the longblock will be completely assembled in the next couple weeks.
                            Pics!
                            Oil block adapter:
                            Xcessive windage tray (pre trimming for clearance):
                            Just back from the machine shop, fresh ground valve seats:
                            Assembling the head:
                            • C
                              C
                              Cobra Rob
                              Looks very nice
                              • R
                                R
                                revolutionz_s13
                                So finally had some time over the last couple weeks to get some more done again. Started cleaning out the engine bay and taking out stuff I dont need anymore. I cut out the battery tray too, that sucked ass. Also pulled the engine bay harness out so I can go through it and check all the wires to make sure they are good, and to add wires I need, and take out ones I dont. I also got everything to start getting the motor more assembled. I was like a 2nd christmas over the last week, a bunch of parts came :icon_cheers: I ran into a snag tonight, I need to get longer spacers made for the fuel rail, the ID1000 injectors + xcessive mani ends up with a much larger gap than what the spacers came with for the oem fuel rail. Pics!
                                Parts!
                                Cleanin a mess
                                Battery tray removed
                                A days carnage
                                Puttin the motor together little by little
                                Its gettin there slowly but surely, needs lots more time and money tho :icon_pale: Feels good to be making progress again after a couple years of it sitting though. Comments, suggestions, and flames welcome 😄
                                • GrrG
                                  GrrG
                                  that thing is gonna be awesome man, good work
                                  • zbrownZ
                                    zbrownZ
                                    Good injector choice
                                    • K
                                      K
                                      Nate, What do you need for spacers for the Fuel rail? I might have something that could work for you. Good to see this thing getting somewhere.
                                      When you need it, I have the tools for adjusting the valves(unless you have bought one) as well as a bunch of shims.
                                      • R
                                        R
                                        revolutionz_s13
                                        I dont know for sure what I'm gonna need for the spacers yet, I have to figure out good way to measure it so I get the right length so that the fuel rail sits parallel with the intake manifold. as far as adjusting the valves, its a little more of a pain in the ass with the supertech lifters, because they are shim under bucket, so after I measure everything, cams have to come all the way back out and the lifters have to be pulled out to put the shim into. which means i cant use your shims either. which sucks, because its about $60 for a set of shims from supertech.
                                        Thanks, although I'm starting to wonder if they will be big enough...it seems like i'm going to have to run them up to like 80psi to get them to flow enough fuel...
                                        • zbrownZ
                                          zbrownZ
                                          They love high pressure and are stable and linear to 95% DC
                                          Same ones I have, idle awesome
