  4. Car Updates / Progress
  5. s13 240sx build
s13 240sx build
26 Posts 13 Posters 10.7k Views
  • zbrownZ
    zbrownZ
    Looks like fun!
    good choice on injectors!
    i like the 044 in series with the walbro too, supposed to work great
    • King RicerK
      King RicerK
      looks fun nate!!
      Trafik Jamz;299122 wrote:
      • 99civic9
        99civic9
        99civic
        i wish i had a bunch of goodies like that laying around !!!
        2000 civic SiR - jdm sickness
        • F
          F
          ForestGreen
          Yummy!
          • R
            R
            revolutionz_s13
            Little update, did some work on the head over the weekend, took it all apart and smoothed out the intake runners and ports on the head a bit...didnt want to go too crazy since I dont have much experience, just wanted to smooth out the flashing from casting and take the roughness down a notch. Waiting on a some valve seals and it will all go back together hopefully towards the end of this week.
            Intake mani runners before:
            Intake port before:
            Exhaust port before:
            Intake mani runners after:
            Intake port after:
            exhaust port after:
            cylinder side of ports after:
            MisterCMK;207559 wrote:
            Of course the Astrovan won. I've seen one-legged children on tricycles beat v6 mustangs.
            • zbrownZ
              zbrownZ
              looks good man!
              • capitljC
                capitljC
                capitlj
                You'd be amazed at how much a little "cleaning" in the heads can accomplish. I never had the cougar dynoed but the E7's I ported seemed to flow really well beyond the RPM range where most "stock" 302's fall flat on their face. Keep up the good work, it looks so much better with the new paint and wheels, can't say I'm a fan of the wheel color tho.
                Mitch Hedberg wrote:
                2004 Impala LS 3.8
                • wesholeW
                  wesholeW
                  Very nice build indeed. Looking forward to seeing this one progress.
                  • D
                    D
                    dis_ill_usions
                    from what I have seen, I suggest staying away from Spec clutches... I had a stage 2 and all it was is just a nice disk with a stock pressure plate...
                    • R
                      R
                      revolutionz_s13
                      My buddy has a stage 3+ in his corvette, it holds pretty good....alot of the KA guys run spec and like them
                      • R
                        R
                        revolutionz_s13
                        Small bit of progress here. Got some more parts, a Skullworks oil block adapter, some AEM pencil coils, an Aeromotive A1000 FPR, and a set of Supertech cam followers (lifters). I sent the head to the machine shop for a 3angle valve job, and then proceed to assemble the head. I also put the oil block adapter on and installed the Xcessive windage tray/crank scraper, and had to do only a slight amount of clearancing for the crankshaft. Im waiting for a couple more things, hopefully the longblock will be completely assembled in the next couple weeks.
                        Pics!
                        Oil block adapter:
                        Xcessive windage tray (pre trimming for clearance):
                        Just back from the machine shop, fresh ground valve seats:
                        Assembling the head:
                        • C
                          C
                          Cobra Rob
                          Looks very nice
                          • R
                            R
                            revolutionz_s13
                            So finally had some time over the last couple weeks to get some more done again. Started cleaning out the engine bay and taking out stuff I dont need anymore. I cut out the battery tray too, that sucked ass. Also pulled the engine bay harness out so I can go through it and check all the wires to make sure they are good, and to add wires I need, and take out ones I dont. I also got everything to start getting the motor more assembled. I was like a 2nd christmas over the last week, a bunch of parts came :icon_cheers: I ran into a snag tonight, I need to get longer spacers made for the fuel rail, the ID1000 injectors + xcessive mani ends up with a much larger gap than what the spacers came with for the oem fuel rail. Pics!
                            Parts!
                            Cleanin a mess
                            Battery tray removed
                            A days carnage
                            Puttin the motor together little by little
                            Its gettin there slowly but surely, needs lots more time and money tho :icon_pale: Feels good to be making progress again after a couple years of it sitting though. Comments, suggestions, and flames welcome 😄
                            • GrrG
                              GrrG
                              that thing is gonna be awesome man, good work
                              • zbrownZ
                                zbrownZ
                                Good injector choice
                                • K
                                  K
                                  Nate, What do you need for spacers for the Fuel rail? I might have something that could work for you. Good to see this thing getting somewhere.
                                  When you need it, I have the tools for adjusting the valves(unless you have bought one) as well as a bunch of shims.
                                  • R
                                    R
                                    revolutionz_s13
                                    I dont know for sure what I'm gonna need for the spacers yet, I have to figure out good way to measure it so I get the right length so that the fuel rail sits parallel with the intake manifold. as far as adjusting the valves, its a little more of a pain in the ass with the supertech lifters, because they are shim under bucket, so after I measure everything, cams have to come all the way back out and the lifters have to be pulled out to put the shim into. which means i cant use your shims either. which sucks, because its about $60 for a set of shims from supertech.
                                    Thanks, although I'm starting to wonder if they will be big enough...it seems like i'm going to have to run them up to like 80psi to get them to flow enough fuel...
                                    • zbrownZ
                                      zbrownZ
                                      They love high pressure and are stable and linear to 95% DC
                                      Same ones I have, idle awesome
                                      • GrrG
                                        GrrG
                                        I dont think you will have too much trouble with the injectors, but i agree you should have gotten 1200s anyway. I suspect you will be out of pump with that walbro trying to run high pressure to compensate.
                                        Aeromotive is now releasing and will be tested in the coming weeks a drop in walbro replacement that is 340lph at 43.5psi vs the walbros 255. It will be $180 and looks to be the answer for all the intank pump users. I would be on the lookout for a bigger injector, maybe see if you can trade yours in on them if they are unused, and try to keep pressure down to 40psi or so base
                                        • R
                                          R
                                          revolutionz_s13
                                          my plan right now is to use the walbro to feed a surge tank, then run a bosch 044 from the surge tank. Im thinking i'll run a 50psi base, and the boost reference will bring it up accordingly, i figure roughly 80 psi max. the injectors at that pressure flow almost 1300cc. The 044 should be able to keep up with that. that aeromotive is a nice option though....
