s13 240sx build
You'd be amazed at how much a little "cleaning" in the heads can accomplish. I never had the cougar dynoed but the E7's I ported seemed to flow really well beyond the RPM range where most "stock" 302's fall flat on their face. Keep up the good work, it looks so much better with the new paint and wheels, can't say I'm a fan of the wheel color tho.
from what I have seen, I suggest staying away from Spec clutches... I had a stage 2 and all it was is just a nice disk with a stock pressure plate...
My buddy has a stage 3+ in his corvette, it holds pretty good....alot of the KA guys run spec and like them
Small bit of progress here. Got some more parts, a Skullworks oil block adapter, some AEM pencil coils, an Aeromotive A1000 FPR, and a set of Supertech cam followers (lifters). I sent the head to the machine shop for a 3angle valve job, and then proceed to assemble the head. I also put the oil block adapter on and installed the Xcessive windage tray/crank scraper, and had to do only a slight amount of clearancing for the crankshaft. Im waiting for a couple more things, hopefully the longblock will be completely assembled in the next couple weeks.
Pics!
Oil block adapter:
Xcessive windage tray (pre trimming for clearance):
Just back from the machine shop, fresh ground valve seats:
Assembling the head:
So finally had some time over the last couple weeks to get some more done again. Started cleaning out the engine bay and taking out stuff I dont need anymore. I cut out the battery tray too, that sucked ass. Also pulled the engine bay harness out so I can go through it and check all the wires to make sure they are good, and to add wires I need, and take out ones I dont. I also got everything to start getting the motor more assembled. I was like a 2nd christmas over the last week, a bunch of parts came :icon_cheers: I ran into a snag tonight, I need to get longer spacers made for the fuel rail, the ID1000 injectors + xcessive mani ends up with a much larger gap than what the spacers came with for the oem fuel rail. Pics!
Parts!
Cleanin a mess
Battery tray removed
A days carnage
Puttin the motor together little by little
Its gettin there slowly but surely, needs lots more time and money tho :icon_pale: Feels good to be making progress again after a couple years of it sitting though. Comments, suggestions, and flames welcome
I dont know for sure what I'm gonna need for the spacers yet, I have to figure out good way to measure it so I get the right length so that the fuel rail sits parallel with the intake manifold. as far as adjusting the valves, its a little more of a pain in the ass with the supertech lifters, because they are shim under bucket, so after I measure everything, cams have to come all the way back out and the lifters have to be pulled out to put the shim into. which means i cant use your shims either. which sucks, because its about $60 for a set of shims from supertech.
zbrown;318528 wrote:
Good injector choice
Thanks, although I'm starting to wonder if they will be big enough...it seems like i'm going to have to run them up to like 80psi to get them to flow enough fuel... -
I dont think you will have too much trouble with the injectors, but i agree you should have gotten 1200s anyway. I suspect you will be out of pump with that walbro trying to run high pressure to compensate.
Aeromotive is now releasing and will be tested in the coming weeks a drop in walbro replacement that is 340lph at 43.5psi vs the walbros 255. It will be $180 and looks to be the answer for all the intank pump users. I would be on the lookout for a bigger injector, maybe see if you can trade yours in on them if they are unused, and try to keep pressure down to 40psi or so base
my plan right now is to use the walbro to feed a surge tank, then run a bosch 044 from the surge tank. Im thinking i'll run a 50psi base, and the boost reference will bring it up accordingly, i figure roughly 80 psi max. the injectors at that pressure flow almost 1300cc. The 044 should be able to keep up with that. that aeromotive is a nice option though....
Ditch the surge tank idea and just get a big enough external pump and sump the tank. If you don't want to sump the tank, mount another pump with the exitsting one in the tank.
Surge tank isn't needed and a waste of time trying to build and fit.
ps. how many times have people had a Walbro pump fail. I haven't known anyone yet.
After doing some more reading, I think you guys are probably right. I will order an aeromotive 340 with a boost-a-pump, which should be more than enough
