My project
i'm stilling in the tuning process. my buddy took out some fuel and added it in other place's. we are planning on turning up the boost some more if we can get the boost controller to work right with the waste gate i'm running.
These are some video's my friend posted of my car
http://www.youtube.com/watch?v=Fg6y2_xVRPQ&list=UU7FGAyX8WqNznoCiXZEb2LA&index=1&feature=plcp
http://www.youtube.com/watch?v=v2dfxbsnSO0&list=UU7FGAyX8WqNznoCiXZEb2LA&index=3&feature=plcp
http://www.youtube.com/watch?v=M_qAaxQajCk&list=UU7FGAyX8WqNznoCiXZEb2LA&index=2&feature=plcp
Also started making a list of part's that will be needed for the 6.0 this winter.
Ran it out at the street legal's this past weekend. My best run was a 10.73 at 127.
http://www.youtube.com/watch?v=cpty7DFOnZ0&list=UU7FGAyX8WqNznoCiXZEb2LA&index=1&feature=plcp
Sorry for the crappy video was taken with a digital camera
zbrown;327234 wrote:
nice work getting into the 10s!Thank's man. When are you coming up and running the rx7?
congrats on getting certed cage and license?
i'm running 15lbs right now. i don't think i'm going to make any changes for now. planning on building a 6.0 for it with an 80mm turbo
are you running a t4 or t6 flanged turbo? i have the feeling i will need to do all of that stuff next year when the 6.0 goes in. at least i have the rollbar in my car already.
I suppose i should do an update. Picked up a used borg warner st80 turbo that has been checked over. Ordered piston's, rod's, cam, balancer, performance lifter's and valve spring's and exhaust valve's for my 6.0 build.
howard's roller cam 232 intake/ 236 exhaust @ .050 .625 lift with the factory rocker ratio
i hope so. have to wait to see what other part's i'll need after the machine shop is done
finally got the block back from the machine shop. got the crankshaft back in. made an intake valley plate. going to start the rest of the assembly this weekend.
i thought i'd give everyone a quick update. motor is put together and run's. i have put about 80 - 100 miles on it since friday night and done some tuning. also saw 7 - 8lbs of boost already and no hicup's or farts so far.
