  4. Car Updates / Progress
  5. My project
My project
70 Posts 13 Posters 21.1k Views
  • legacy-user-3898L
    legacy-user-3898L
    legacy-user-3898
    zbrown;327234 wrote:
    nice work getting into the 10s!
    Thank's man. When are you coming up and running the rx7?
    • zbrownZ
      zbrownZ
      i am 8.50 certed now, hope to be up for the 2 day with some changes
      how much boost where u on and do you plan on any changes?
      • legacy-user-3898L
        legacy-user-3898L
        legacy-user-3898
        congrats on getting certed cage and license?
        i'm running 15lbs right now. i don't think i'm going to make any changes for now. planning on building a 6.0 for it with an 80mm turbo
        • zbrownZ
          zbrownZ
          nice it sounds like a plan
          yeah all the licensing bs is done too, i am trying out an 88 on mine to see what the big turbine does
          • DaveHD
            DaveHD
            88mm? Weak.
            • zbrownZ
              zbrownZ
              lol, you better of sprinkled some of that special go fast dust on it for me.... i know you have enough 🙂
              • legacy-user-3898L
                legacy-user-3898L
                legacy-user-3898
                are you running a t4 or t6 flanged turbo? i have the feeling i will need to do all of that stuff next year when the 6.0 goes in. at least i have the rollbar in my car already.
                • legacy-user-3898L
                  legacy-user-3898L
                  legacy-user-3898
                  I suppose i should do an update. Picked up a used borg warner st80 turbo that has been checked over. Ordered piston's, rod's, cam, balancer, performance lifter's and valve spring's and exhaust valve's for my 6.0 build.
                  • GrrG
                    GrrG
                    what are the new cam specs
                    • legacy-user-3898L
                      legacy-user-3898L
                      legacy-user-3898
                      howard's roller cam 232 intake/ 236 exhaust @ .050 .625 lift with the factory rocker ratio
                      • GrrG
                        GrrG
                        good job, that should work well.
                        • legacy-user-3898L
                          legacy-user-3898L
                          legacy-user-3898
                          i hope so. have to wait to see what other part's i'll need after the machine shop is done
                          • legacy-user-3898L
                            legacy-user-3898L
                            legacy-user-3898
                            finally got the block back from the machine shop. got the crankshaft back in. made an intake valley plate. going to start the rest of the assembly this weekend.
                            • legacy-user-3898L
                              legacy-user-3898L
                              legacy-user-3898
                              i thought i'd give everyone a quick update. motor is put together and run's. i have put about 80 - 100 miles on it since friday night and done some tuning. also saw 7 - 8lbs of boost already and no hicup's or farts so far.
                              • legacy-user-3898L
                                legacy-user-3898L
                                legacy-user-3898
                                So far this year i have ran a 10.15 @ 138 on 15lbs of boost. Had to upgrade my fuel pump and now looking at a convertor upgrade due to 19% slippage 😞
                                • legacy-user-3898L
                                  legacy-user-3898L
                                  legacy-user-3898
                                  Figured out my problem. Found out the exhaust housing on the st80 was to small and was choking it's self. So we made an adaptor to go from a t-4 to a t-6 and used my buddies s475 and his 28 inch slick's finally got in to the 9's. Here is a video that he got
                                  http://www.youtube.com/watch?v=sUbPDuEFRs8
                                  • legacy-user-3898L
                                    legacy-user-3898L
                                    legacy-user-3898
                                    Quick update got the powerglide built and ordered new intake and planning how to get a t-6 turbo under the hood
