My project
I suppose i should do an update. Picked up a used borg warner st80 turbo that has been checked over. Ordered piston's, rod's, cam, balancer, performance lifter's and valve spring's and exhaust valve's for my 6.0 build.
howard's roller cam 232 intake/ 236 exhaust @ .050 .625 lift with the factory rocker ratio
i hope so. have to wait to see what other part's i'll need after the machine shop is done
finally got the block back from the machine shop. got the crankshaft back in. made an intake valley plate. going to start the rest of the assembly this weekend.
i thought i'd give everyone a quick update. motor is put together and run's. i have put about 80 - 100 miles on it since friday night and done some tuning. also saw 7 - 8lbs of boost already and no hicup's or farts so far.
So far this year i have ran a 10.15 @ 138 on 15lbs of boost. Had to upgrade my fuel pump and now looking at a convertor upgrade due to 19% slippage
Figured out my problem. Found out the exhaust housing on the st80 was to small and was choking it's self. So we made an adaptor to go from a t-4 to a t-6 and used my buddies s475 and his 28 inch slick's finally got in to the 9's. Here is a video that he got
Quick update got the powerglide built and ordered new intake and planning how to get a t-6 turbo under the hood
