  4. Borg Warner S200 Honda D Series Setup
33 Posts 19 Posters 1.8k Views
    ignition box possibly?
      It's not an ignition issue. Honda has a rather good stock ignition system.
        a hotter spark wouldnt hurt...
        • krzydrftr93K Offline
          krzydrftr93
          That is pretty sick. I wish i had that motor in my car.
          Post some video up from the track once it gets out there
          Matt
          92 Civic HB
          JDM d15b w/14b@8psi
            whats the highest d series HP record? anyone ever hit 500?
              krzydrftr93
              theres a guy on honda tech with 502whp D-series
              Matt
              92 Civic HB
              JDM d15b w/14b@8psi
                link or pix?
                  krzydrftr93
                  cant find pics for that one...go to turbod16 There are some 450plus ones there.
                  ANd the guy on HT with the 500whp d is member TURBODCX. Sold the car for around 11,500
                  Matt
                  92 Civic HB
                  JDM d15b w/14b@8psi
                  • darkelvisD Offline
                    darkelvisD Offline
                    darkelvis
                    Ignition boxes don't produce a "hotter spark." And yes, a hotter spark WOULD hurt (which is why you want to run colder plugs).
                      correct me if i am wrong.
                      an upgraded ignition would help buy prevent spark blow out allowing you to run more gap on your plugs,
                      edit: im dumb should have read it twice
                      • XJHEADX Offline
                        XJHEADX Offline
                        XJHEAD
                        an upgraded ignition would help buy prevent spark blow out allowing you to run less gap on your plugs,
                        OK, you're wrong
                        7.64 @ 187 3400 lbs. on KORN
                        TTSBF
                        RTCTTFMF PTOSITW
                        • bader3245B Offline
                          bader3245B Offline
                          bader3245
                          You have it exactly backwards.
                          2008 Ford F-150 FX4
                          2006 Honda CRF250R
                          2006 Honda CBR1000RR
                            whoops i just reread that, run more plug gap whops, my bad
