  4. Car Updates / Progress
  5. s13 240sx build
s13 240sx build
26 Posts 13 Posters 10.2k Views
  • R Offline
    R Offline
    revolutionz_s13
    Well, I finally started ordering parts for my car again. Its been sitting in storage for about the last 2 years, due to being broke and in school. I'm going for at least 450whp on e85, would like to see 500whp, but that might be a stretch. I still need a whole grip of parts (and money) , but I think I have a pretty good start on it. On to the parts list/pics....
    Powertrain
    Wiseco Pistons, 9.0 comp
    Eagle Rods
    ACL bearings
    ARP Main Studs
    ARP head studs
    JWT s1 camshafts
    Koyo Radiator
    Garrett GT3076R turbo, .82 a/r
    Tanabe Concept G catback
    Nismo motor mounts and trans mount
    centerforce dual friction clutch
    nismo 2way lsd
    c's short shifter
    dual 10" electric fans
    Walbro fuel pump
    JWT Cam Gears
    Xcessive Windage Tray w/ crank scraper
    ATI super damper crank pulley
    Xcessive Intake Mani w/q45 flange and SS throttle cable bracket
    Xcessive lowering motor mount brackets
    Cometic Head Gasket
    JGS turbo mani and oil lines
    AEM Fuel Rail
    BC springs and retainers
    supertech valve seals
    BC SS Valves, Std size
    Suspension:
    JIC flt-a2 coilovers
    cusco front tie bar
    Suspension Tech. F&R sway bars
    spl tension rods w/ brake cooling air deflectors
    spl ruca
    sentra se-r brembo calipers
    r32 skyline rear calipers (might sell and get ksports front and rear instead)
    JIC front and rear strut bars
    autopower race roll bar
    tein tie rods
    TechnoToyTuning subframe collars
    Energy suspension poly bushings in the rest of the arms
    Exterior
    SSR Professor MS1 wheels 17x9,17x10 +24, 1/4" spacers on fronts
    (Yes, they are 4 lug!)
    front 255/40, rear 275/40
    ARP wheel studs
    Bomex front lip
    silvia sideskirts
    What I started with, about 5 years ago:
    Pulling old motor, tearing it down to send the block off, sanding it down for paint:
    Block back from machine shop, car back from first attempt at paint, put on suspension parts, test fit wheels:
    Bunch of the parts I have sitting in my bedroom, waiting to be bolted to something...(no longer have the emanage, sold it to get aem ems)
    Parts I'm planning on collecting over the winter:
    Vibrant intercooler
    Synapse Synchronic WG and BOV
    oil cooler
    One piece steel driveshaft
    ID 1000cc injectors
    Spec aluminum flywheel
    Spec Stage 3+ clutch
    Circuit sports clutch pivot
    AEM Coilpacks
    AEM twinfire
    AEM FPR
    AEM EMS
    AEM Wideband
    Aeroquip -6 Fuel lines
    Bosch 044 inline fuel pump (fed by in-tank walbro)
    Apexi boost controller
    Ksport 13" front and rear brakes
    I also have some work to do in the interior, and plan on stitch welding most of the car and possibly doing tubs in the front.
    Shooting to get it tuned next summer, and completely finished by next fall. Still needs alot of work, but I'll be starting on the money sucking piece of metal this week, and I'll post updates as I make progress on this current monstrosity.
    > MisterCMK;207559 wrote:
    > Of course the Astrovan won. I've seen one-legged children on tricycles beat v6 mustangs.
      aliengotpsi
      Looks nice!!!
      What are your plans for this car? drag drift DD?
      Kevin Smith
      Straightlinedetailing.com
      • R Offline
        R Offline
        revolutionz_s13
        planning pretty much for roadrace/auto-x and just an all around fun car. I would like to take it to BIR when its done, and Im sure i'll make a few passes at sabin also...
          Looks like fun!
          good choice on injectors!
          i like the 044 in series with the walbro too, supposed to work great
            looks fun nate!!
            • 99civic9 Offline
              99civic9 Offline
              99civic
              i wish i had a bunch of goodies like that laying around !!!
              2000 civic SiR - jdm sickness
              • F Offline
                F Offline
                ForestGreen
                Yummy!
                • R Offline
                  R Offline
                  revolutionz_s13
                  Little update, did some work on the head over the weekend, took it all apart and smoothed out the intake runners and ports on the head a bit...didnt want to go too crazy since I dont have much experience, just wanted to smooth out the flashing from casting and take the roughness down a notch. Waiting on a some valve seals and it will all go back together hopefully towards the end of this week.
                  Intake mani runners before:
                  Intake port before:
                  Exhaust port before:
                  Intake mani runners after:
                  Intake port after:
                  exhaust port after:
                  cylinder side of ports after:
                    looks good man!
                    • capitljC Offline
                      capitljC Offline
                      capitlj
                      You'd be amazed at how much a little "cleaning" in the heads can accomplish. I never had the cougar dynoed but the E7's I ported seemed to flow really well beyond the RPM range where most "stock" 302's fall flat on their face. Keep up the good work, it looks so much better with the new paint and wheels, can't say I'm a fan of the wheel color tho.
                      > Mitch Hedberg wrote:
                      2004 Impala LS 3.8
                        Very nice build indeed. Looking forward to seeing this one progress.
                        • D Offline
                          D Offline
                          dis_ill_usions
                          from what I have seen, I suggest staying away from Spec clutches... I had a stage 2 and all it was is just a nice disk with a stock pressure plate...
                          • R Offline
                            R Offline
                            revolutionz_s13
                            My buddy has a stage 3+ in his corvette, it holds pretty good....alot of the KA guys run spec and like them
                            • R Offline
                              R Offline
                              revolutionz_s13
                              Small bit of progress here. Got some more parts, a Skullworks oil block adapter, some AEM pencil coils, an Aeromotive A1000 FPR, and a set of Supertech cam followers (lifters). I sent the head to the machine shop for a 3angle valve job, and then proceed to assemble the head. I also put the oil block adapter on and installed the Xcessive windage tray/crank scraper, and had to do only a slight amount of clearancing for the crankshaft. Im waiting for a couple more things, hopefully the longblock will be completely assembled in the next couple weeks.
                              Pics!
                              Oil block adapter:
                              Xcessive windage tray (pre trimming for clearance):
                              Just back from the machine shop, fresh ground valve seats:
                              Assembling the head:
                              • C Offline
                                C Offline
                                Cobra Rob
                                Looks very nice
                                • R Offline
                                  R Offline
                                  revolutionz_s13
                                  So finally had some time over the last couple weeks to get some more done again. Started cleaning out the engine bay and taking out stuff I dont need anymore. I cut out the battery tray too, that sucked ass. Also pulled the engine bay harness out so I can go through it and check all the wires to make sure they are good, and to add wires I need, and take out ones I dont. I also got everything to start getting the motor more assembled. I was like a 2nd christmas over the last week, a bunch of parts came :icon_cheers: I ran into a snag tonight, I need to get longer spacers made for the fuel rail, the ID1000 injectors + xcessive mani ends up with a much larger gap than what the spacers came with for the oem fuel rail. Pics!
                                  Parts!
                                  Cleanin a mess
                                  Battery tray removed
                                  A days carnage
                                  Puttin the motor together little by little
                                  Its gettin there slowly but surely, needs lots more time and money tho :icon_pale: Feels good to be making progress again after a couple years of it sitting though. Comments, suggestions, and flames welcome 😄
                                    that thing is gonna be awesome man, good work
                                      Good injector choice
                                        Nate, What do you need for spacers for the Fuel rail? I might have something that could work for you. Good to see this thing getting somewhere.
                                        When you need it, I have the tools for adjusting the valves(unless you have bought one) as well as a bunch of shims.
                                        • R Offline
                                          R Offline
                                          revolutionz_s13
                                          I dont know for sure what I'm gonna need for the spacers yet, I have to figure out good way to measure it so I get the right length so that the fuel rail sits parallel with the intake manifold. as far as adjusting the valves, its a little more of a pain in the ass with the supertech lifters, because they are shim under bucket, so after I measure everything, cams have to come all the way back out and the lifters have to be pulled out to put the shim into. which means i cant use your shims either. which sucks, because its about $60 for a set of shims from supertech.
                                          Thanks, although I'm starting to wonder if they will be big enough...it seems like i'm going to have to run them up to like 80psi to get them to flow enough fuel...
