nascar>f1? wtf
to me, nascar>f1 because nascar's dont have any aids as f1 cars do (i.e. traction control) because its not allowed...i realize that f1 drivers go through huge amounts of g-force and higher speeds, but from a driving aspect, i think it'd be harder to drive a car with 800hp and no traction control rather than a 900hp car with traction control...also, when you say f1 car's shift, arent they push button or somthing (i could be wrong on that one)...my .02
torbs wrote:
to me, nascar>f1 because nascar's dont have any aids as f1 cars do (i.e. traction control) because its not allowed...i realize that f1 drivers go through huge amounts of g-force and higher speeds, but from a driving aspect, i think it'd be harder to drive a car with 800hp and no traction control rather than a 900hp car with traction control...also, when you say f1 car's shift, arent they push button or somthing (i could be wrong on that one)...my .02paddle shifters
torbs wrote:
to me, nascar>f1 because nascar's dont have any aids as f1 cars do (i.e. traction control) because its not allowed...i realize that f1 drivers go through huge amounts of g-force and higher speeds, but from a driving aspect, i think it'd be harder to drive a car with 800hp and no traction control rather than a 900hp car with traction control...also, when you say f1 car's shift, arent they push button or somthing (i could be wrong on that one)...my .02It might sound easy, go rent F1 2002 from easports and you'll see.
not trying to sound like an ass here, but it seems like traction control would be more necessary on cars that have to turn BOTH directions than it would be for cars that turn ONE direction....you can probably set the suspension up easy enough for NASCAR to safely run w/o traction control.
tjamz wrote:
not trying to sound like an ass here, but it seems like traction control would be more necessary on cars that have to turn BOTH directions than it would be for cars that turn ONE direction....you can probably set the suspension up easy enough for NASCAR to safely run w/o traction control.if you've ever heard the term used in a nascar race called "like stepping on eggshells" they are talking about how the drivers have to ease onto the throttle, otherwise they'll end up in the wall...traction control would help nascar drivers a great deal...they do have traction control, its called skill with the accelerator and knowing how far you can push it before it breaks loose...one direction or not, you cant have traction 100% of the time....another thing is that nascar's get "loose" all the time, meaning the rear end wants to slip out...traction control would help that problem emmensly, but its outlawed in nascar, otherwise im sure all the cars would have it.
T ! N wrote:
It might sound easy, go rent F1 2002 from easports and you'll see.never said it was easy...im just comparing the two different styles
id also like to add that yes, f1 cars are faster and have more technology, but with the technology comes driving aids which take away from the "skill" part of racing...its almost like cheeting :eek:
tjamz wrote:
yes, but nascar drivers get to change tires, F1 does not (ok...they can change ONE tire per race...not one set, one tire.) Trust me traction control doesn't prevent spinouts in F1, they get loose plenty often as well.f1 tires actually last the whole race, nascar's HAVE to change tires or they'll blow em all the time...unless goodyear comes up with some pimp shit tires for them...
torbs wrote:
f1 tires actually last the whole race, nascar's HAVE to change tires or they'll blow em all the time...unless goodyear comes up with some pimp shit tires for them...maybe if they had more driver skill they could use the same tires the whole race :p:eek::p:eek::p
tjamz wrote:
maybe if they had more driver skill they could use the same tires the whole race :p:eek::p:eek::pwow...thats just like saying "your wrx can get the same distance in 5 gallons as my honda insite can...thats only if you have enough driver skill though"
if he had enough skill to find a really really long downhill portion he could
